Date/Time: Sun, 29 Dec 2024 15:09:08 +0000
DOM
View Count: 696
[2016-05-13 18:42:24] |
User615377 - Posts: 12 |
Hi I am using Transact - i can not seem to get a standalone DOM - do you have this? I have trading DOM on and included in the charts but nothing showing if i turn on draw dom chart on graph - numbers appear but not very clearly thanks |
[2016-05-13 18:58:38] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
