Date/Time: Thu, 26 Nov 2026 23:40:39 +0000
delay in charts updating
View Count: 997
| [2016-05-13 15:35:44] |
| User227674 - Posts: 3 |
Hi, last days I'm experiencing delays in charts updating - charts are frozen for a few seconds and then updated (see attached picture). Can you, please, help me to fix it? I have latest version of SC, real time data from SC and latest version of TWS (Interactive Brokers).
Private File |
| [2016-05-13 21:54:29] |
What you see may be normal. Refer to help topic 4: Https://www.sierrachart.com/index.php?l=helpdetails4.html You are using the Interactive Brokers data for those charts. We recommend using the Sierra Chart Exchange Data Feed for the cash indices. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes For the symbols of those charts you will need: CBOE Indices Russell Indices NASDAQ indices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-13 21:54:38
