Date/Time: Sun, 27 Sep 2026 16:17:50 +0000
Spreadsheet data
View Count: 1067
| [2016-05-13 15:16:59] |
| User57210 - Posts: 121 |
Hi, I'm attempting to use data from a "numbers bars" study, but when I add a spreadsheet study to the numbers bars chart, it does not display the numbers bars data anywhere that I see. Specifically, said in another way, I just want to access bid/ask volume for each level traded for range bars. |
| [2016-05-13 17:19:06] |
For this you need to use the Advanced Custom Study Interface and Language. Advanced Custom Study Interface and Language (ACSIL) You need to use this ACSIL member to access the volume at price data. ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-13 17:23:29
