Date/Time: Sun, 19 Jan 2025 12:41:04 +0000
Processor and RAM requirements
View Count: 4018
[2016-05-13 09:37:02]
User34124 - Posts: 279
Hello I will be upgrading my computer largely to be able to load the charts quicker when I switch symbols. I want to store about 1400 days in bar history, and be able to change the symbol with the least amount of processing time. At the moment it takes around 20secs on a quad core Xeon 1.6ghz and 8gb DDR3 RAM. What would you recommend is the best specs to get?
[2016-05-13 10:06:26]
Are you referring to Historical Daily or Intraday charts?
[2016-05-13 15:05:19]
Intraday
Historical are no problem as they are not made up of 1sec bar data
[2016-05-13 17:39:05]
If you want to load 1400 days of 1 second bars into an Intraday chart, that is not going to load fast.
20 seconds does not necessarily sound unreasonable. But certainly you can get a faster computer. As far as what the specifications should be, you just have to determine this. The main thing is to use a Solid State Drive.
[2016-05-14 14:48:26]
I didn't say I want to load 1400 days of 1 second bars.
And OK that is one thing you recommend, SSD. What is the next in order of priority, CPU or RAM?
[2016-05-14 20:56:34]
Both CPU speed and memory are important. But the CPU is going to make the most difference.
[2016-05-15 09:21:44]
Would multi-core be more appropriate given the type of processing required?
[2016-05-15 10:15:02]
Yes of course. You are already using a multicore CPU. All CPUs for desktops and notebooks are multicore.
You want at least a quad core.
[2016-05-20 18:10:59]
Cavalry3162 - Posts: 523
SC, does sierrachart use multiple cores? or does it run only on one core?
thanks,
Andreas
[2016-05-20 18:12:42]
It does use multiple cores/threads.
Although study calculations and graphics are all done on a single thread.
In our next release coming out today, file writing will be on a background thread.
Date Time Of Last Edit: 2016-05-20 18:13:18
[2016-05-20 18:14:12]
i wonder whats more important, a faster 4 core vs. a little bit slower 6 core cpu... i7 5930k vs. i7 6700k
any thoughts on that?
thanks,
Andreas
Date Time Of Last Edit: 2016-05-20 18:15:40
[2016-05-20 18:18:34]
It is hard to say. It all depends upon what you are doing with your computer.
Generally we would think more cores would be better.
[2016-05-20 18:21:00]
yeah, i mean, SieraChart related.. would it benefit from the 2 additional cores?
[2016-05-20 18:24:25]
Only if you are running multiple instances of Sierra Chart will there be a benefit. Like if you are running three or four of them.
Date Time Of Last Edit: 2016-05-20 18:24:38
[2016-05-20 19:57:56]
User704990 - Posts: 18
I'd go with the 4790k, unless they keep lga 1150 thru the next generation (they usually don't). Best single thread performance.
Date Time Of Last Edit: 2016-05-20 19:58:47
[2016-05-20 20:10:36]
User11942 - Posts: 298
If you don't need extra PCI-E lines, stick to 1151 and i7-6700K. 64 GB of RAM will be enough for the next 3-5 years. It is also better to buy M.2 SSD (on NVMe chips) instead of a regular SSD.
[2016-05-20 20:13:32]
yeah, i am building my pc's since 20 years.. so i know some stuff, reason for asking was just if sierrachart would use it through potential excessive threading.
i have both of them (with a Samsung 950 PRO M.2 and 64GB of RAM), am just trying to figure out which one should get my wife :)
however, appreciate the response.
thanks,
Andreas
Date Time Of Last Edit: 2016-05-20 20:16:23
