Date/Time: Thu, 09 Jan 2025 19:11:40 +0000
Cumulative Delta - Volume study does not respond to "invert chart"
View Count: 1025
[2016-05-12 12:02:01] |
Dema - Posts: 42 |
Hi Team, The Cumulative Delta - Volume study does not respond to "invert chart" (in chart settings, Advanced 2). The Cumulative Delta - Up/Down Tick Volume study does though. Could you please fix the Cumulative Delta - Volume study to work with chart invert? Thankyou. Date Time Of Last Edit: 2016-05-12 12:02:33
[2016-05-12 17:59:41] |
This is not something we are willing to spend time on right now. It will have to wait until later. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-17 02:25:12] |
Dema - Posts: 42 |
Ok I will use the Study/Price overlay to reference this study with a multiplier of -1 to workaround. Thankyou.
[2016-08-08 11:52:00] |
User94740 - Posts: 333 |
Hi Dema, did you manage to get the cumulative delta-volume study reciprocal? I am trying to get the Volume by Price study's reciprocal, but I am failing. Maybe you have a tip?
[2016-08-08 16:24:01] |
sc, is the user Dema still with sc?
