Date/Time: Fri, 07 Feb 2025 14:55:08 +0000
Color Bar Based On Alert Condition Not updating
View Count: 1108
[2016-05-11 15:08:09] |
sjkafeero - Posts: 21 |
The "color bar based on alert condition" is updating in realtime on the individual charts with their respective studies. However. When I overlay the study of the 1 hour chart onto the 15 min chart study, I have to manually refresh the alert to color the bars. What might I be doing wrong?
[2016-05-11 17:26:01] |
What are the Input settings of the Study/Price Overlay study? We might also need to get your Chartbook so we can test this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-11 23:49:58] |
Please find herein the requested information. Thank you. http://www.sierrachart.com/image.php?Image=1463010159529.png |
Private File Attachment Deleted. Private File |
[2016-05-13 03:10:15] |
We are checking on this now. However, no longer use the Point and Figure study and instead the new Intraday Chart Bar Period >> Point and Figure Bar in Chart >> Chart Settings for this.
[2016-05-13 06:51:49] |
Thank you. I await your response
[2016-05-16 09:57:15] |
What you are doing is very elaborate for us to analyze in detail but we have a general sense of what the problem may be. We need a couple of weeks to think about a solution. We expect to be able to provide a solution. The problem could also be related to study calculation precedence: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyCalculationPrecedence Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-16 09:57:38
[2016-05-25 05:06:24] |
We are implementing a solution based upon what we think the problem is. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-28 22:28:43] |
Please try version 1420 and let us know if the problem is resolved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-28 22:29:02
