Date/Time: Mon, 25 Nov 2024 05:34:35 +0000
ACSIL - Function to check if depth data is populated
View Count: 805
[2016-05-11 00:40:59]
ejtrader - Posts: 688
SC Team - Generally it takes few seconds initially when the feed is connected / chart is loaded - for the depth data to be populated.
Based on my observation - sc platform initially populates only bestBid/bestOffer and then after few seconds it populates the rest of the depth data.
Is there any ASCIL function available to check - if the depth data is populated and available? If this is not available, would you please see if you can make it available?
thanks
Date Time Of Last Edit: 2016-05-11 00:41:41
[2016-05-11 01:09:54]
We can add this.
It will be called sc.IsMarketDepthDataCurrentlyAvailable
[2024-03-30 21:12:35]
User891636 - Posts: 5
the function is in the documentation but it looks like is not available anymore.
[2024-03-30 22:03:18]
Sierra_Chart Engineering - Posts: 17169
It may never have been added.
You can check for market depth data with these functions:
sc.GetAskMarketDepthNumberOfLevels
sc.GetBidMarketDepthNumberOfLevels
