Date/Time: Mon, 03 Feb 2025 16:59:50 +0000
Mouse scroll wheel not working on QuoteBoard list
View Count: 963
[2016-05-10 20:00:24]
User742717 Mike - Posts: 86
It works on fine on DOM, T&S etc
Not sure why it doesn't work on QB list, it really should though.
V:1400
edit: V:1409 same
Date Time Of Last Edit: 2016-05-10 20:07:35
[2016-05-11 22:57:08]
Also related to the QB.
Using the table cursor (green), hitting enter on the symbol field gets the text entry popup box up.
But this doesn't work on the comment fields, which is where most of the text entry/editing is done.
Also tested with/without the 'in Cell editing' feature.
V:1409
[2016-05-13 07:40:37]
We are not accepting new suggestions at this time. We simply have no time to be getting involved with either of these items at this time.
Date Time Of Last Edit: 2016-05-13 07:40:55
[2016-05-17 09:41:10]
Clearly I wasn't reporting any new suggestions, these are existing features which don't work as expected.
I thought I was submitting a bug report?
Maybe keeping a track of these though, would be good, ie with a forum type (like user discussion).
Just trying to help, but sounds like you guys are too busy with the new features, that's cool.
Thanks anyway.
Cheers
Mike.
Date Time Of Last Edit: 2016-05-17 09:59:04
[2019-11-16 00:59:25]
TedMar - Posts: 190
In fact is bad situation, if u move wheel , then its scrolling horizontaly when columns are outside QuoteWindow. :-(
Any news in this case?
Date Time Of Last Edit: 2019-11-16 01:43:58
[2019-11-18 03:00:45]
We will look into this.
[2019-11-18 04:18:36]
Scroll wheel support for the quote board will be out in the next release.
