Date/Time: Wed, 01 Jan 2025 13:55:18 +0000
TPO profile
View Count: 1033
[2016-05-09 22:46:08] |
User182649 - Posts: 31 |
Good evening! I have been using the TPO and VbP studies and I think they offer tremendous value; especially, when compared to some of the other platforms. One question/request I have is the following: I routinely expand the daily profile to observe each 30 minute period as the session develops. However, when you do expand, you lose the daily composite profile and must switch back and forth. Currently, is there a way to duplicate another copy of the daily composite (without duplicating another whole chart) which stays in original profile shape while allowing the second one to be expanded. I have not come across this anywhere in the settings or TPO documentation section. If not, is this something that could be easily developed and implemented. It would really be helpful. Thanks for the consideration! |
[2016-05-10 05:37:29] |
This is on our longer term to do list. It is not currently supported.
[2016-05-13 15:18:35] |
Usul - Posts: 16 |
I support this request and I am pleased to know that it is already in the to do list. I would also like to add the following requests: 1) when using VbP with a TPO chart, I would like the chance to enable only the current session VbP: I do not need to see past sessions VbPs, but they occupy space and thus make the chart more confused 2) capability of enable/disable the current overnight session profile, which should have separate and customizable color set (VA highlight, etc)from the main TPO (regular trading hours) chart thank you! |
[2016-05-16 09:07:33] |
This capability is coming: 1) when using VbP with a TPO chart, I would like the chance to enable only the current session VbP: I do not need to see past sessions VbPs, but they occupy space and thus make the chart more confused We will try to get it out by the end of next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-16 15:26:23] |
Usul - Posts: 16 |
Great, thank you! Any chance for the second? Thank you guys |
[2016-05-18 23:34:36] |
WarriorTrader - Posts: 245 |
Thanks for the consideration! You may want to try my Custom Profile study, which displays a second profile in the fill space after the last profile. Be sure to download the last version of the study. Custom Market Profile Chart Good luck, -WT |
