Date/Time: Sun, 09 Feb 2025 03:52:52 +0000
Increase Font on Values Title bar or Customize the bar
View Count: 1061
[2016-05-09 16:54:51] |
SK - Posts: 33 |
How to increase the font size on the values title bar shown for a symbol along with all the studies data. Also i'd like to customize what needs to be shown , as I don't need some studies data to be shown there. They are too small. was trying to find some documentation on it, but could not. Pls. see attached pic
2016-05-09_12-49-03.jpg / V - Attached On 2016-05-09 16:53:42 UTC - Size: 26.93 KB - 307 views |
[2016-05-09 19:35:37] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html#Fonts https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#RegionDataLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-09 22:54:39] |
SK - Posts: 33 |
How I increase the font size just for the region data line but not other areas in the chart? Global settings increase font size for all text in a chart... |
[2016-05-10 00:35:08] |
This is not supported and we are not accepting feature requests at this time.
[2020-08-12 12:45:04] |
RolandC - Posts: 54 |
Can I add that a whole lot of studies need to be used because this text is so small. Such as Displaying the Symbol in large text and the Bar Period
