Date/Time: Fri, 20 Sep 2024 00:41:18 +0000
Show Menu and ALT key
View Count: 1620
[2013-07-10 09:40:53] |
JP - Posts: 24 |
Every time I press the ALT key the menu shows up in the detached chart. Is there a way to have this disabled when the ALT key is pressed? it is a nuisance to have to hide the menu every time. Thank you |
[2013-07-10 12:01:29] |
We will look into this and see what can be done.
[2013-07-11 08:05:28] |
JP - Posts: 24 |
Thank you. Hope you can find a solution. |
