Date/Time: Sat, 28 Dec 2024 22:41:30 +0000
Deleting multiple tools with same LineNumber crashes in recent builds.
View Count: 759
[2016-05-07 12:53:32] |
gomifromparis - Posts: 244 |
Well title pretty much sums it up, check the file
testdeletetool.cpp - Attached On 2016-05-07 12:53:04 UTC - Size: 2 KB - 447 views |
[2016-05-07 18:12:24] |
We are checking on this.
[2016-05-07 19:07:21] |
Al SC Developer - Posts: 434 |
This is addressed in the next version.
