Date/Time: Sat, 28 Dec 2024 22:55:31 +0000
TPO different values
View Count: 800
[2016-05-07 07:33:32] |
EuropeanTrader - Posts: 290 |
Hello, please help me with the following. It seems I can't find the reason for this problem. Attached you will find a file that shows 240m and 60m charts where indicator templates are the same. However if you look for example upper blue line which should be last weeks VAH, 240m shows different value compared to 60m. I don't understand why. Please advise, thank you! |
[2016-05-08 21:12:05] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
