Date/Time: Sun, 20 Sep 2026 22:33:13 +0000
'next chartbook' - possible bug
View Count: 1014
| [2016-05-07 05:14:41] |
| User730732 - Posts: 12 |
Hi SC, when switching the chartbook - through the menu, a hotkey or control bar button - it is not possible to switch two times in a row. The control bar button gets greyed out and one first has to activate a chart for it to work again. Please check. |
| [2016-05-07 05:48:23] |
This will be corrected in the next release.
