Date/Time: Mon, 05 Oct 2026 05:34:44 +0000
can not change textcolor market depth window
View Count: 1127
| [2016-05-06 15:31:12] |
| Cavalry3162 - Posts: 523 |
Hello Support, according to your help page, the text of the market depth window is controlled by the chart text settings. however, i can not change its color to white. am i missing something? please advise. thanks, Andreas |
| [2016-05-06 15:32:36] |
and it would be great to control that independently.. as i'd like to have it a bit of a bigger font in the market depth, and do not want big font sizes in my chart. but thats a "nice to have".. just the color would be great. |
| [2016-05-07 06:53:03] |
Setting the foreground color for the text of the Market Depth window will be supported in the next release.
| [2016-05-08 15:53:06] |
found the setting in the latest prerelease, thank you for that. however, its not changing anything, maybe not yet wired? thanks, Andreas |
| [2016-05-08 20:31:52] |
Yes, it has not yet been implemented.
