Date/Time: Sat, 28 Dec 2024 23:37:09 +0000
Multiple MoveToBreakEven in ACSIL
View Count: 771
[2016-05-06 14:09:20]
cclarke - Posts: 5
From the trade window it is possible to specify two Move to BreakEven actions. In ACSIL, using NewOrder.MoveToBreakEven makes setting a single MoveToBreakEven action straight forward. However, I have not been able to find documentation or an example to set multiple MoveToBreakEven actions in ACSIL. Is it possible to set multiple MoveToBreakEven steps in ACSIL? If not, is there a preferred work around?
Thanks!
[2016-05-06 15:19:25]
This is not supported and there are no plans for this.
You have to manually perform the order modifications in the ACSIL trading system.
[2016-05-06 17:07:00]
cclarke - Posts: 5
Understood. Thanks.
