Date/Time: Tue, 22 Sep 2026 11:50:53 +0000
Study for drawing a vertical line on every expiry of the futures contract
View Count: 1149
| [2016-05-06 11:30:02] |
| BrMa - Posts: 80 |
Dear ladies and gentlemen, I'm trying to automatically draw vertical lines on a daily chart on every day the underlying future contract expires. I was not able to find a study doing this - is there anything like this available? If it's not a study, is there any other way of doing this automatically? This would be great! Thanks a lot in advance! Regards, Markus |
| [2016-05-06 15:17:28] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#DisplayingRolloverDatesContractMonths Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-07 11:03:27] |
| BrMa - Posts: 80 |
Thanks a lot for your immediate support! Works great! |
