Date/Time: Tue, 04 Nov 2025 17:11:16 +0000
question on sc.Subgraph[].DataColor[] for GDT_POINT_AND_FIGURE_BARS
View Count: 1377
[2016-05-05 15:55:51]
@sstfrederik - Posts: 410
When manually changing the primary color of the High in a pnf chart I see the color change. Would like to use a secondary color in ACSIL to do the same.
I used the point and figure study form studies8.cpp. I did some very basic testing and it does not seem to work. Am I missing something?
in sc.SetDefaults added:
sc.GraphUsesChartColors = 0;//
High.SecondaryColor = RGB(0,0,255);//
High.SecondaryColorUsed = true;//
In the main loop I added:
High.DataColor[OutputIndex] = High.SecondaryColor; //
[2016-05-05 19:23:58]
We have to add support for this. This will be done today.
[2016-05-06 07:40:35]
This will be supported in the next release. It is untested so let us know if it works properly.
We do not expect any problems. It is very efficiently implemented.
[2016-05-06 14:51:04]
Thanks. Will wait for 1407 release than. I will let you know in this thread.
[2016-05-07 15:10:31]
Its working as expected. Many thanks.
[2016-05-07 15:21:52]
however with the new installation the sierrachart.h is not installed properly.
contents of sierrachart.h are:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /downloads/1407/sierrachart.h was not found on this server.</p>
</body></html>
therefore unable to compile new studies. will use 1406 for that.
Date Time Of Last Edit: 2016-05-07 16:39:53
[2016-05-07 18:14:05]
This will be solved in a few hours. We are working on a new installer and have a problem we need to correct.
