Date/Time: Sat, 28 Dec 2024 23:06:44 +0000
Some charts are not visible
View Count: 579
[2016-05-05 03:41:28] |
nicktrader - Posts: 722 |
After starting the platform not all charts are shown as you can see in the arrached filfe. All day I have to restore the "missing" charts and than I save it. But next time same old story. |
Charts.png / V - Attached On 2016-05-05 03:36:30 UTC - Size: 92.77 KB - 208 views |
[2016-05-05 04:03:03] |
From our limited perspective it is hard for us to know exactly what is happening and what the solution is. We can suggested that some of the charts are minimized, offscreen, or you have some kind of system problem. It certainly is not some problem within Sierra Chart randomly hiding a chart. Try selecting Window >> Tile Horizontally /Vertically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
