Date/Time: Thu, 24 Sep 2026 19:35:20 +0000
Data Feed
View Count: 1140
| [2016-05-04 19:52:44] |
| julian pineda - Posts: 60 |
hi, where i could get a demo data feed? i still have time on SC but i dont have data feed
| [2016-05-04 20:13:35] |
Did you need real-time data? What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: Is Historical and Real-time Data Included? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-04 20:15:41] |
the Mini s&p. just that one
| [2016-05-04 22:02:45] |
| [2016-05-04 22:04:03] |
yes
| [2016-05-04 22:05:49] |
Therefore, you can use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed The data feed is 35 USD per month + 42 USD for the CME exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-04 22:07:12] |
ok, but there is not a demo? to test first?
| [2016-05-04 22:17:24] |
The first two weeks of this data feed is 5 USD when you activate the trial for it. The first month for the CME exchange fee is free. Therefore, for the next two weeks you can have the data feed for 5 USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
