Date/Time: Sat, 28 Dec 2024 23:30:41 +0000
Eurex entitlement
View Count: 675
[2016-05-04 17:11:59] |
cmb999 - Posts: 211 |
hello, it seems eurex symbols not displaying bid/ask after subscribing to realtime.
[2016-05-04 17:22:35] |
We do not see a problem with the EUREX data feed. Restart Sierra Chart. Go to a chart for a EUREX symbol and select Window >> Current Quote Window. Do you not see the current Bid and Ask price there? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-04 17:33:25] |
it works now, and i am just nitpicking, but would be great if subscribing to various feeds could be accomodated without restarting the entire program, thanks, |
[2016-05-04 17:39:20] |
Yes this will come soon.
