Date/Time: Thu, 17 Sep 2026 15:57:39 +0000
can't see the history data on the charts
View Count: 860
| [2016-05-04 16:12:04] |
| User212558 - Posts: 2 |
i am using the # sign on the suffix of the contract name to see the history on the charts, but it works only on few contracts(ES,NQ,YM,RJ) for example if i want to see the history on 6E it doesn't work. do you know why? |
| [2016-05-04 16:25:09] |
Do not use the #. That is not supported. Use the Continuous Futures Contract feature: Continuous Futures Contract Charts Also understand that in the case of a trial account the amount of historical data you can get when using the Continuous Futures Contract feature is limited to about two years. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-04 16:25:56
