Date/Time: Sat, 28 Dec 2024 23:06:29 +0000
Did something change with the way tools are handled?
View Count: 725
[2016-05-04 01:16:34] |
i960 - Posts: 360 |
I used to be able to right click out of a drawing being made and then browse the chart with the hand/crosshair as normal. This has now changed and keeps my tool selected (even though I do not want that) and is becoming extremely annoying. I don't know if I'm losing my mind here and this how it's always been or what, but it seems different now.
[2016-05-04 02:49:51] |
Nothing has changed recently that we are aware of. We tested what you describe and it does work as you describe. In this particular case you will have to go back to the Hand tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-04 03:28:40] |
i960 - Posts: 360 |
I might just be misremembering things in my normal workflow (been doing other things for a while), so apologies and disregard.
