Date/Time: Sat, 28 Dec 2024 22:55:58 +0000
VXX Symbol - updates with SC Data but not with Trading Account Data
View Count: 1367
[2016-05-03 19:55:06]
User615377 - Posts: 12
Hi
I have upgraded my data feed to inc S&P Indicies.
When i connect via Transact the symbol VXX stops working but when i connect to the SC Data it works?
can you help
thanks
[2016-05-03 20:58:00]
There should not be a problem with this.
Restart Sierra Chart. Use the Transact Trading service.
Open a chart for VXX and then post a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2016-05-04 07:13:46]
Software version: 1400 | 2016-05-04 08:09:39
Uses New Spreadsheets | 2016-05-04 08:09:39
Usage end date: 2016-05-11 | 2016-05-04 08:09:39
Enabled for: Advanced Features. | 2016-05-04 08:09:39
Enabled for: Advanced Features 2. | 2016-05-04 08:09:39
Enabled for: Sierra Chart Historical Data Service. | 2016-05-04 08:09:39
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-05-04 08:09:39
Enabled for: INDEXES_DATA_BARCHART | 2016-05-04 08:09:39
Enabled for: CME (Trading Account Required) | 2016-05-04 08:09:39
Enabled for: CBOT (Trading Account Required) | 2016-05-04 08:09:39
Enabled for: COMEX (Trading Account Required) | 2016-05-04 08:09:39
Enabled for: NYMEX (Trading Account Required) | 2016-05-04 08:09:39
Enabled for: S&P Indices | 2016-05-04 08:09:39
Enabled for: CME (Trading Account Required) - S&P Indices | 2016-05-04 08:09:39
Received 1 data feed usernames. | 2016-05-04 08:09:39
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-05-04 08:09:39
Current selected Data/Trading service: TransAct Trading | 2016-05-04 08:09:39
Chart Update Interval: 500 | 2016-05-04 08:09:39
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2016-05-04 08:09:39
2016-05-04 08:09:43 Local computer time | 2016-05-04 08:09:39
2016-05-04 07:09:43 Local computer time in UTC | 2016-05-04 08:09:39
2016-05-04 08:09:43 Local computer time in SC Time Zone | 2016-05-04 08:09:39
2016-05-04 07:09:19 Server time in UTC | 2016-05-04 08:09:39
Local computer UTC time and Server UTC time difference: 23 seconds. | 2016-05-04 08:09:39
Program path: C:\SierraChart\ | 2016-05-04 08:09:39
Data Files path: C:\SierraChart\Data\ | 2016-05-04 08:09:39
OS Version Number: 6.1 | 2016-05-04 08:09:39
Locale Setting: C | 2016-05-04 08:09:39
Checking for new symbol settings for ta | 2016-05-04 08:09:39
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-05-04 08:09:39
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-05-04 08:09:39
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-05-04 08:09:39
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-05-04 08:09:39
Symbol settings are up-to-date for ta | 2016-05-04 08:09:44
Files to Open on Start up | Opening file: Correlation.cht | 2016-05-04 08:09:46
Files to Open on Start up | Opening file: Fib.cht | 2016-05-04 08:09:46
Files to Open on Start up | Opening file: 60 min TPO.cht | 2016-05-04 08:09:46
Files to Open on Start up | Opening file: Trading.cht | 2016-05-04 08:09:46
Files to Open on Start up | File does not exist: C:\SierraChart\Data\Depth.cht | 2016-05-04 08:09:46
Mapping NQM6 to NQM16. Service code: cme | 2016-05-04 08:09:48
Intraday data recording state for symbol NQM6 is set to download 'Pending'. | 2016-05-04 08:09:48
HD Request # 2 | Downloading Intraday chart data for NQM6 to the file NQM6.scid. Service: cme | 2016-05-04 08:09:48
HD Request # 2 | Download start Date-Time: 2016-05-03 21:14:59.000 | 2016-05-04 08:09:48
HD Request # 2 | Using server: scdf1.sierracharts.com port 10149 | 2016-05-04 08:09:48
Mapping ESM6 to ESM16. Service code: cme | 2016-05-04 08:09:48
Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-05-04 08:09:48
Mapping YMM6 to YMM16. Service code: cbot | 2016-05-04 08:09:48
Intraday data recording state for symbol YMM6 is set to download 'Pending'. | 2016-05-04 08:09:48
Mapping $INX to $INX. Service code: sp.index | 2016-05-04 08:09:48
Intraday data recording state for symbol $INX is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol NISS-NASDAQ is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol NISS-TF is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-04 08:09:48
Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-05-04 08:09:48
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-04 08:09:48
Socket (4) | Connected. | 2016-05-04 08:09:48
HD Request # 2 | Sending historical data logon request message. | 2016-05-04 08:09:48
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-04 08:09:48
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-04 08:09:48
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-04 08:09:48
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-04 08:09:48
HD Request # 2 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:14:59. Record interval: 1. Symbol: NQM16 | 2016-05-04 08:09:49
HD Request # 2 | Decompressing data. | 2016-05-04 08:09:49
HD Request # 2 | Receiving Intraday data for NQM6 starting at 2016-05-03 21:14:59 | 2016-05-04 08:09:49
HD Request # 2 | Timestamp of first Intraday data file record written: 2016-05-03 21:14:59 | 2016-05-04 08:09:49
Socket (4) | Shutdown and closed. | 2016-05-04 08:09:49
The network socket for historical data has been closed. | 2016-05-04 08:09:49
HD Request # 2 | Historical data for NQM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:49
HD Request # 2 | Received 2570 records from 2016-05-03 21:14:59 to 2016-05-04 07:59:22 (10.7 hours) and wrote 2570 records for NQM6 | 2016-05-04 08:09:49
HD Request # 2 | Intraday download COMPLETE for NQM6. Completion time: 0s. Unique request ID: 1 | 2016-05-04 08:09:49
Removed historical data download ID 1 | 2016-05-04 08:09:49
HD Request # 3 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cme | 2016-05-04 08:09:49
HD Request # 3 | Download start Date-Time: 2016-05-03 21:14:59.000 | 2016-05-04 08:09:49
HD Request # 3 | Using server: scdf2.sierracharts.com port 10149 | 2016-05-04 08:09:49
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-04 08:09:49
Socket (5) | Connected. | 2016-05-04 08:09:49
HD Request # 3 | Sending historical data logon request message. | 2016-05-04 08:09:49
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:14:59. Record interval: 1. Symbol: ESM16 | 2016-05-04 08:09:49
HD Request # 3 | Decompressing data. | 2016-05-04 08:09:49
HD Request # 3 | Receiving Intraday data for ESM6 starting at 2016-05-03 21:14:59 | 2016-05-04 08:09:49
HD Request # 3 | Timestamp of first Intraday data file record written: 2016-05-03 21:14:59 | 2016-05-04 08:09:49
TransAct Trading | Starting server: C:\SierraChart\Transact\TransactToSierraBridge.exe | 2016-05-04 08:09:50
Socket (5) | Shutdown and closed. | 2016-05-04 08:09:50
The network socket for historical data has been closed. | 2016-05-04 08:09:50
HD Request # 3 | Historical data for ESM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:50
HD Request # 3 | Received 5381 records from 2016-05-03 21:14:59 to 2016-05-04 07:59:26 (10.7 hours) and wrote 5381 records for ESM6 | 2016-05-04 08:09:50
HD Request # 3 | Intraday download COMPLETE for ESM6. Completion time: 1s. Unique request ID: 2 | 2016-05-04 08:09:50
Removed historical data download ID 2 | 2016-05-04 08:09:50
HD Request # 4 | Downloading Intraday chart data for YMM6 to the file YMM6.scid. Service: cbot | 2016-05-04 08:09:50
HD Request # 4 | Download start Date-Time: 2016-05-03 21:14:59.000 | 2016-05-04 08:09:50
HD Request # 4 | Using server: scdf1.sierracharts.com port 10149 | 2016-05-04 08:09:50
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-04 08:09:50
Socket (6) | Connected. | 2016-05-04 08:09:50
HD Request # 4 | Sending historical data logon request message. | 2016-05-04 08:09:50
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:14:59. Record interval: 1. Symbol: YMM16 | 2016-05-04 08:09:50
HD Request # 4 | Decompressing data. | 2016-05-04 08:09:50
HD Request # 4 | Receiving Intraday data for YMM6 starting at 2016-05-03 21:14:59 | 2016-05-04 08:09:50
HD Request # 4 | Timestamp of first Intraday data file record written: 2016-05-03 21:14:59 | 2016-05-04 08:09:50
Socket (6) | Shutdown and closed. | 2016-05-04 08:09:51
The network socket for historical data has been closed. | 2016-05-04 08:09:51
HD Request # 4 | Historical data for YMM6 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:51
HD Request # 4 | Received 2989 records from 2016-05-03 21:14:59 to 2016-05-04 07:59:26 (10.7 hours) and wrote 2989 records for YMM6 | 2016-05-04 08:09:51
HD Request # 4 | Intraday download COMPLETE for YMM6. Completion time: 1s. Unique request ID: 3 | 2016-05-04 08:09:51
Removed historical data download ID 3 | 2016-05-04 08:09:51
HD Request # 5 | Downloading Intraday chart data for $INX to the file $INX.scid. Service: sp.index | 2016-05-04 08:09:51
HD Request # 5 | Download start Date-Time: 2016-05-03 21:20:01.000 | 2016-05-04 08:09:51
HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2016-05-04 08:09:51
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-04 08:09:51
Socket (7) | Connected. | 2016-05-04 08:09:51
HD Request # 5 | Sending historical data logon request message. | 2016-05-04 08:09:51
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:20:01. Record interval: 1. Symbol: $INX | 2016-05-04 08:09:51
HD Request # 5 | Decompressing data. | 2016-05-04 08:09:51
HD Request # 5 | Receiving Intraday data for $INX starting at 2016-05-03 21:20:01 | 2016-05-04 08:09:51
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-05-03 21:20:01 | 2016-05-04 08:09:51
HD Request # 5 | Historical data for $INX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:51
Socket (7) | Shutdown and closed. | 2016-05-04 08:09:51
HD Request # 5 | Received 2 records from 2016-05-03 21:20:01 to 2016-05-03 21:30:51 (10.8 minutes) and wrote 2 records for $INX | 2016-05-04 08:09:51
HD Request # 5 | Intraday download COMPLETE for $INX. Completion time: 0s. Unique request ID: 4 | 2016-05-04 08:09:51
Removed historical data download ID 4 | 2016-05-04 08:09:51
HD Request # 6 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2016-05-04 08:09:51
HD Request # 6 | Download start Date-Time: 2016-05-03 21:29:56.000 | 2016-05-04 08:09:51
HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:09:51
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:09:52
TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2016-05-04 08:09:52
Socket (9) | Connected. | 2016-05-04 08:09:52
TransAct Trading | Connected to server. | 2016-05-04 08:09:52
TransAct Trading | Sending logon request message. | 2016-05-04 08:09:52
Socket (8) | Connected. | 2016-05-04 08:09:52
HD Request # 6 | Sending historical data logon request message. | 2016-05-04 08:09:52
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:29:56. Record interval: 1. Symbol: NISS-NYSE | 2016-05-04 08:09:52
HD Request # 6 | Decompressing data. | 2016-05-04 08:09:52
HD Request # 6 | Receiving Intraday data for NISS-NYSE starting at 2016-05-03 21:29:56 | 2016-05-04 08:09:52
HD Request # 6 | Timestamp of first Intraday data file record written: 2016-05-03 21:29:56 | 2016-05-04 08:09:52
HD Request # 6 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:53
Socket (8) | Shutdown and closed. | 2016-05-04 08:09:53
The network socket for historical data has been closed. | 2016-05-04 08:09:53
HD Request # 6 | Received 6483 records from 2016-05-03 21:29:56 to 2016-05-04 02:01:20 (4.5 hours) and wrote 6483 records for NISS-NYSE | 2016-05-04 08:09:53
HD Request # 6 | Intraday download COMPLETE for NISS-NYSE. Completion time: 2s. Unique request ID: 5 | 2016-05-04 08:09:53
Removed historical data download ID 5 | 2016-05-04 08:09:53
HD Request # 7 | Downloading Intraday chart data for NISS-NASDAQ to the file NISS-NASDAQ.scid. Service: statscalc | 2016-05-04 08:09:53
HD Request # 7 | Download start Date-Time: 2016-05-03 21:29:56.000 | 2016-05-04 08:09:53
HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2016-05-04 08:09:53
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-04 08:09:53
Socket (10) | Connected. | 2016-05-04 08:09:53
HD Request # 7 | Sending historical data logon request message. | 2016-05-04 08:09:53
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:29:56. Record interval: 1. Symbol: NISS-NASDAQ | 2016-05-04 08:09:53
HD Request # 7 | Decompressing data. | 2016-05-04 08:09:53
HD Request # 7 | Receiving Intraday data for NISS-NASDAQ starting at 2016-05-03 21:29:56 | 2016-05-04 08:09:54
HD Request # 7 | Timestamp of first Intraday data file record written: 2016-05-03 21:29:56 | 2016-05-04 08:09:54
HD Request # 7 | Historical data for NISS-NASDAQ is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:54
Socket (10) | Shutdown and closed. | 2016-05-04 08:09:54
The network socket for historical data has been closed. | 2016-05-04 08:09:54
HD Request # 7 | Received 6483 records from 2016-05-03 21:29:56 to 2016-05-04 02:01:20 (4.5 hours) and wrote 6483 records for NISS-NASDAQ | 2016-05-04 08:09:54
HD Request # 7 | Intraday download COMPLETE for NISS-NASDAQ. Completion time: 0s. Unique request ID: 6 | 2016-05-04 08:09:54
Removed historical data download ID 6 | 2016-05-04 08:09:54
HD Request # 8 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2016-05-04 08:09:54
HD Request # 8 | Download start Date-Time: 2016-05-03 21:29:56.000 | 2016-05-04 08:09:54
HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2016-05-04 08:09:54
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-04 08:09:54
Socket (11) | Connected. | 2016-05-04 08:09:54
HD Request # 8 | Sending historical data logon request message. | 2016-05-04 08:09:54
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:29:56. Record interval: 1. Symbol: NISS-SP | 2016-05-04 08:09:55
HD Request # 8 | Decompressing data. | 2016-05-04 08:09:55
HD Request # 8 | Receiving Intraday data for NISS-SP starting at 2016-05-03 21:29:56 | 2016-05-04 08:09:55
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-05-03 21:29:56 | 2016-05-04 08:09:55
HD Request # 8 | Historical data for NISS-SP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:55
Socket (11) | Shutdown and closed. | 2016-05-04 08:09:55
The network socket for historical data has been closed. | 2016-05-04 08:09:55
HD Request # 8 | Received 6483 records from 2016-05-03 21:29:56 to 2016-05-04 02:01:20 (4.5 hours) and wrote 6483 records for NISS-SP | 2016-05-04 08:09:55
HD Request # 8 | Intraday download COMPLETE for NISS-SP. Completion time: 1s. Unique request ID: 7 | 2016-05-04 08:09:55
Removed historical data download ID 7 | 2016-05-04 08:09:55
HD Request # 9 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2016-05-04 08:09:55
HD Request # 9 | Download start Date-Time: 2016-05-03 21:29:56.000 | 2016-05-04 08:09:55
HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:09:55
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:09:55
Socket (12) | Connected. | 2016-05-04 08:09:55
HD Request # 9 | Sending historical data logon request message. | 2016-05-04 08:09:55
HD Request # 9 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:29:56. Record interval: 1. Symbol: NISS-TF | 2016-05-04 08:09:56
HD Request # 9 | Decompressing data. | 2016-05-04 08:09:56
HD Request # 9 | Receiving Intraday data for NISS-TF starting at 2016-05-03 21:29:56 | 2016-05-04 08:09:56
HD Request # 9 | Timestamp of first Intraday data file record written: 2016-05-03 21:29:56 | 2016-05-04 08:09:56
Socket (12) | Shutdown and closed. | 2016-05-04 08:09:56
HD Request # 9 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:56
The network socket for historical data has been closed. | 2016-05-04 08:09:56
HD Request # 9 | Received 6483 records from 2016-05-03 21:29:56 to 2016-05-04 02:01:20 (4.5 hours) and wrote 6483 records for NISS-TF | 2016-05-04 08:09:56
HD Request # 9 | Intraday download COMPLETE for NISS-TF. Completion time: 1s. Unique request ID: 8 | 2016-05-04 08:09:56
Removed historical data download ID 8 | 2016-05-04 08:09:56
HD Request # 10 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc | 2016-05-04 08:09:56
HD Request # 10 | Download start Date-Time: 2016-05-03 21:29:56.000 | 2016-05-04 08:09:56
HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2016-05-04 08:09:56
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-04 08:09:56
Socket (13) | Connected. | 2016-05-04 08:09:56
HD Request # 10 | Sending historical data logon request message. | 2016-05-04 08:09:56
HD Request # 10 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:29:56. Record interval: 1. Symbol: UDVR-NYSE | 2016-05-04 08:09:56
HD Request # 10 | Decompressing data. | 2016-05-04 08:09:56
HD Request # 10 | Receiving Intraday data for UDVR-NYSE starting at 2016-05-03 21:29:56 | 2016-05-04 08:09:56
HD Request # 10 | Timestamp of first Intraday data file record written: 2016-05-03 21:29:56 | 2016-05-04 08:09:56
HD Request # 10 | Historical data for UDVR-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:57
Socket (13) | Shutdown and closed. | 2016-05-04 08:09:57
The network socket for historical data has been closed. | 2016-05-04 08:09:57
HD Request # 10 | Received 6483 records from 2016-05-03 21:29:56 to 2016-05-04 02:01:20 (4.5 hours) and wrote 6483 records for UDVR-NYSE | 2016-05-04 08:09:57
HD Request # 10 | Intraday download COMPLETE for UDVR-NYSE. Completion time: 0s. Unique request ID: 9 | 2016-05-04 08:09:57
Removed historical data download ID 9 | 2016-05-04 08:09:57
HD Request # 11 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-04 08:09:57
HD Request # 11 | Download start Date-Time: 2016-05-03 21:05:00.000 | 2016-05-04 08:09:57
HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2016-05-04 08:09:57
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-04 08:09:57
Socket (14) | Connected. | 2016-05-04 08:09:57
HD Request # 11 | Sending historical data logon request message. | 2016-05-04 08:09:57
HD Request # 11 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:05:00. Record interval: 1. Symbol: TICK-NYSE | 2016-05-04 08:09:57
HD Request # 11 | Decompressing data. | 2016-05-04 08:09:57
HD Request # 11 | Receiving Intraday data for TICK-NYSE starting at 2016-05-03 21:05:00 | 2016-05-04 08:09:57
HD Request # 11 | Timestamp of first Intraday data file record written: 2016-05-03 21:05:00 | 2016-05-04 08:09:57
HD Request # 11 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-05-04 08:09:57
Socket (14) | Shutdown and closed. | 2016-05-04 08:09:57
HD Request # 11 | Received 1 record from 2016-05-03 21:05:00 to 2016-05-03 21:05:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2016-05-04 08:09:57
HD Request # 11 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 10 | 2016-05-04 08:09:57
Removed historical data download ID 10 | 2016-05-04 08:09:57
HD Request # 12 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: equities.us | 2016-05-04 08:09:57
HD Request # 12 | Download start Date-Time: 2016-05-03 20:39:21.000 | 2016-05-04 08:09:57
HD Request # 12 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:09:57
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:09:57
Socket (15) | Connected. | 2016-05-04 08:09:58
HD Request # 12 | Sending historical data logon request message. | 2016-05-04 08:09:58
HD Request # 12 | Error downloading historical Intraday data for VXX. Historical data logon error: Invalid/missing data for service code: equities.us | 2016-05-04 08:09:58
Socket (15) | Shutdown and closed. | 2016-05-04 08:09:58
The network socket for historical data has been closed. | 2016-05-04 08:09:58
HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VXX | 2016-05-04 08:09:58
HD Request # 12 | Intraday download COMPLETE for VXX. Completion time: 1s. Unique request ID: 11 | 2016-05-04 08:09:58
Removed historical data download ID 11 | 2016-05-04 08:09:58
TransAct Trading | Received logon response. | 2016-05-04 08:10:45
TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2016-05-04 08:10:45
TransAct Trading | Server protocol version: 4. Client protocol version: 7 | 2016-05-04 08:10:45
TransAct Trading | Successfully connected. Operation Successful. | 2016-05-04 08:10:45
TransAct Trading | Trading is supported. | 2016-05-04 08:10:45
TransAct Trading | Order cancel and replace is supported. | 2016-05-04 08:10:45
TransAct Trading | Connected to data and trading server. | 2016-05-04 08:10:45
Mapping $INX to $INX. Service code: sp.index | 2016-05-04 08:10:45
SC Data - All Services | Starting real-time market data updates for: $INX. ID: 1 | 2016-05-04 08:10:45
SC Data - All Services | Using username 0 | 2016-05-04 08:10:45
SC Data - All Services | Connecting to the server scdf2.sierracharts.com. Port 443 | 2016-05-04 08:10:45
Intraday data recording state for symbol $INX is set to download 'Pending'. | 2016-05-04 08:10:45
Delaying start of download for $INX | 2016-05-04 08:10:45
Mapping ESM6 to ESM16. Service code: cme | 2016-05-04 08:10:45
SC Data - All Services | Starting real-time market data updates for: ESM16. ID: 2 | 2016-05-04 08:10:45
Intraday data recording state for symbol ESM6 is set to download 'Pending'. | 2016-05-04 08:10:45
TransAct Trading | Starting real-time market data updates for: VXX. ID: 3 | 2016-05-04 08:10:45
Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-05-04 08:10:45
Symbol Error - VXX is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: NISS-NYSE. ID: 4 | 2016-05-04 08:10:45
SC DTC Data | Connecting to the server ds4.sierracharts.com. Port 10048 | 2016-05-04 08:10:45
Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2016-05-04 08:10:45
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-04 08:10:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: NISS-NASDAQ. ID: 5 | 2016-05-04 08:10:45
Intraday data recording state for symbol NISS-NASDAQ is set to download 'Pending'. | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: NISS-SP. ID: 6 | 2016-05-04 08:10:45
Intraday data recording state for symbol NISS-SP is set to download 'Pending'. | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: NISS-TF. ID: 7 | 2016-05-04 08:10:45
Intraday data recording state for symbol NISS-TF is set to download 'Pending'. | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: UDVR-NYSE. ID: 8 | 2016-05-04 08:10:45
Intraday data recording state for symbol UDVR-NYSE is set to download 'Pending'. | 2016-05-04 08:10:45
Socket (16) | Connected. | 2016-05-04 08:10:45
SC Data - All Services | Connected to server. | 2016-05-04 08:10:45
SC Data - All Services | Sending Encoding Request to server | 2016-05-04 08:10:45
Socket (17) | Connected. | 2016-05-04 08:10:45
SC DTC Data | Connected to server. | 2016-05-04 08:10:45
SC DTC Data | Sending Encoding Request to server | 2016-05-04 08:10:45
SC DTC Data | Starting real-time market data updates for: TICK-NYSE. ID: 9 | 2016-05-04 08:10:46
Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2016-05-04 08:10:46
Mapping NQM6 to NQM16. Service code: cme | 2016-05-04 08:10:46
SC Data - All Services | Starting real-time market data updates for: NQM16. ID: 10 | 2016-05-04 08:10:46
Intraday data recording state for symbol NQM6 is set to download 'Pending'. | 2016-05-04 08:10:46
Mapping YMM6 to YMM16. Service code: cbot | 2016-05-04 08:10:46
SC Data - All Services | Starting real-time market data updates for: YMM16. ID: 11 | 2016-05-04 08:10:46
Intraday data recording state for symbol YMM6 is set to download 'Pending'. | 2016-05-04 08:10:46
HD Request # 13 | Downloading Intraday chart data for $INX to the file $INX.scid. Service: sp.index | 2016-05-04 08:10:46
HD Request # 13 | Download start Date-Time: 2016-05-03 21:30:51.000 | 2016-05-04 08:10:46
HD Request # 13 | Using server: scdf1.sierracharts.com port 10149 | 2016-05-04 08:10:46
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-04 08:10:46
SC Data - All Services | Setting DTC Encoding to Binary VLS | 2016-05-04 08:10:46
SC Data - All Services | Sending logon request message. | 2016-05-04 08:10:46
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-05-04 08:10:46
SC DTC Data | Sending logon request message. | 2016-05-04 08:10:46
Socket (18) | Connected. | 2016-05-04 08:10:46
HD Request # 13 | Sending historical data logon request message. | 2016-05-04 08:10:46
SC Data - All Services | Received logon response. | 2016-05-04 08:10:46
SC Data - All Services | Server Name: SC Realtime Server. | 2016-05-04 08:10:46
SC Data - All Services | Server protocol version: 7. Client protocol version: 7 | 2016-05-04 08:10:46
SC Data - All Services | Successfully connected. | 2016-05-04 08:10:46
SC Data - All Services | Restarting real-time data updates for symbol: $INX -> $INX | 2016-05-04 08:10:46
SC Data - All Services | Restarting real-time data updates for symbol: ESM6 -> ESM16 | 2016-05-04 08:10:46
SC Data - All Services | Restarting real-time data updates for symbol: NQM6 -> NQM16 | 2016-05-04 08:10:46
SC Data - All Services | Restarting real-time data updates for symbol: YMM6 -> YMM16 | 2016-05-04 08:10:46
HD Request # 13 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:30:51. Record interval: 1. Symbol: $INX | 2016-05-04 08:10:46
HD Request # 13 | Decompressing data. | 2016-05-04 08:10:46
HD Request # 13 | Receiving Intraday data for $INX starting at 2016-05-03 21:30:51 | 2016-05-04 08:10:46
HD Request # 13 | Timestamp of first Intraday data file record written: 2016-05-03 21:30:51 | 2016-05-04 08:10:46
Socket (18) | Shutdown and closed. | 2016-05-04 08:10:46
The network socket for historical data has been closed. | 2016-05-04 08:10:46
HD Request # 13 | Received 1 record from 2016-05-03 21:30:51 to 2016-05-03 21:30:51 (0.0 seconds) and wrote 1 record for $INX | 2016-05-04 08:10:46
HD Request # 13 | Intraday download COMPLETE for $INX. Completion time: 0s. Unique request ID: 12 | 2016-05-04 08:10:46
Removed historical data download ID 12 | 2016-05-04 08:10:46
Real-time Intraday chart data file updates started for $INX | 2016-05-04 08:10:46
Opened cached Intraday file: C:\SierraChart\Data\$INX.scid | 2016-05-04 08:10:46
Intraday chart data file opened for $INX | 2016-05-04 08:10:46
Delaying start of download for ESM6 | 2016-05-04 08:10:46
SC DTC Data | Received logon response. | 2016-05-04 08:10:46
SC DTC Data | Server Name: SC Realtime Server. | 2016-05-04 08:10:46
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-05-04 08:10:46
SC DTC Data | Successfully connected. | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: NISS-NASDAQ | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: NISS-NYSE | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: NISS-SP | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: NISS-TF | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: TICK-NYSE | 2016-05-04 08:10:46
SC DTC Data | Restarting real-time data updates for symbol: UDVR-NYSE | 2016-05-04 08:10:46
HD Request # 14 | Downloading Intraday chart data for ESM6 to the file ESM6.scid. Service: cme | 2016-05-04 08:10:51
HD Request # 14 | Download start Date-Time: 2016-05-04 07:59:26.000 | 2016-05-04 08:10:51
HD Request # 14 | Using server: scdf2.sierracharts.com port 10149 | 2016-05-04 08:10:51
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-04 08:10:51
Socket (19) | Connected. | 2016-05-04 08:10:51
HD Request # 14 | Sending historical data logon request message. | 2016-05-04 08:10:51
HD Request # 14 | Requesting Intraday data. Start Date-Time: 2016-05-04 07:59:26. Record interval: 1. Symbol: ESM16 | 2016-05-04 08:10:51
HD Request # 14 | Decompressing data. | 2016-05-04 08:10:51
HD Request # 14 | Receiving Intraday data for ESM6 starting at 2016-05-04 07:59:26 | 2016-05-04 08:10:51
HD Request # 14 | Timestamp of first Intraday data file record written: 2016-05-04 07:59:26 | 2016-05-04 08:10:51
Socket (19) | Shutdown and closed. | 2016-05-04 08:10:51
The network socket for historical data has been closed. | 2016-05-04 08:10:51
HD Request # 14 | Received 375 records from 2016-05-04 07:59:26 to 2016-05-04 08:10:26 (11.0 minutes) and wrote 375 records for ESM6 | 2016-05-04 08:10:51
Added 6 Time and Sales records to Intraday data file for ESM6 after download. | 2016-05-04 08:10:51
HD Request # 14 | Intraday download COMPLETE for ESM6. Completion time: 0s. Unique request ID: 13 | 2016-05-04 08:10:51
Removed historical data download ID 13 | 2016-05-04 08:10:51
Real-time Intraday chart data file updates started for ESM6 | 2016-05-04 08:10:51
Opened cached Intraday file: C:\SierraChart\Data\ESM6.scid | 2016-05-04 08:10:51
Intraday chart data file opened for ESM6 | 2016-05-04 08:10:51
HD Request # 15 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: equities.us | 2016-05-04 08:10:51
HD Request # 15 | Download start Date-Time: 2016-05-03 20:39:21.000 | 2016-05-04 08:10:51
HD Request # 15 | Using server: ds5.sierracharts.com port 10149 | 2016-05-04 08:10:51
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-04 08:10:51
Socket (20) | Connected. | 2016-05-04 08:10:52
HD Request # 15 | Sending historical data logon request message. | 2016-05-04 08:10:52
Socket (20) | Shutdown and closed. | 2016-05-04 08:10:52
The network socket for historical data has been closed. | 2016-05-04 08:10:52
HD Request # 15 | Error downloading historical Intraday data for VXX. Historical data logon error: Invalid/missing data for service code: equities.us | 2016-05-04 08:10:52
HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VXX | 2016-05-04 08:10:52
HD Request # 15 | Intraday download COMPLETE for VXX. Completion time: 1s. Unique request ID: 14 | 2016-05-04 08:10:52
Removed historical data download ID 14 | 2016-05-04 08:10:52
Real-time Intraday chart data file updates started for VXX | 2016-05-04 08:10:52
Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-05-04 08:10:52
Intraday chart data file opened for VXX | 2016-05-04 08:10:52
HD Request # 16 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2016-05-04 08:10:52
HD Request # 16 | Download start Date-Time: 2016-05-04 02:01:20.000 | 2016-05-04 08:10:52
HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:10:52
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:10:52
Socket (21) | Connected. | 2016-05-04 08:10:52
HD Request # 16 | Sending historical data logon request message. | 2016-05-04 08:10:52
HD Request # 16 | Requesting Intraday data. Start Date-Time: 2016-05-04 02:01:20. Record interval: 1. Symbol: NISS-NYSE | 2016-05-04 08:10:52
HD Request # 16 | Decompressing data. | 2016-05-04 08:10:52
HD Request # 16 | Receiving Intraday data for NISS-NYSE starting at 2016-05-04 02:01:20 | 2016-05-04 08:10:52
HD Request # 16 | Timestamp of first Intraday data file record written: 2016-05-04 02:01:20 | 2016-05-04 08:10:52
Socket (21) | Shutdown and closed. | 2016-05-04 08:10:52
HD Request # 16 | Received 1 record from 2016-05-04 02:01:20 to 2016-05-04 02:01:20 (0.0 seconds) and wrote 1 record for NISS-NYSE | 2016-05-04 08:10:52
HD Request # 16 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 15 | 2016-05-04 08:10:52
Removed historical data download ID 15 | 2016-05-04 08:10:52
Real-time Intraday chart data file updates started for NISS-NYSE | 2016-05-04 08:10:52
Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2016-05-04 08:10:52
Intraday chart data file opened for NISS-NYSE | 2016-05-04 08:10:52
HD Request # 17 | Downloading Intraday chart data for NISS-NASDAQ to the file NISS-NASDAQ.scid. Service: statscalc | 2016-05-04 08:10:52
HD Request # 17 | Download start Date-Time: 2016-05-04 02:01:20.000 | 2016-05-04 08:10:52
HD Request # 17 | Using server: ds4.sierracharts.com port 10149 | 2016-05-04 08:10:52
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-04 08:10:52
Socket (22) | Connected. | 2016-05-04 08:10:53
HD Request # 17 | Sending historical data logon request message. | 2016-05-04 08:10:53
HD Request # 17 | Requesting Intraday data. Start Date-Time: 2016-05-04 02:01:20. Record interval: 1. Symbol: NISS-NASDAQ | 2016-05-04 08:10:53
HD Request # 17 | Decompressing data. | 2016-05-04 08:10:53
HD Request # 17 | Receiving Intraday data for NISS-NASDAQ starting at 2016-05-04 02:01:20 | 2016-05-04 08:10:53
HD Request # 17 | Timestamp of first Intraday data file record written: 2016-05-04 02:01:20 | 2016-05-04 08:10:53
Socket (22) | Shutdown and closed. | 2016-05-04 08:10:53
The network socket for historical data has been closed. | 2016-05-04 08:10:53
HD Request # 17 | Received 1 record from 2016-05-04 02:01:20 to 2016-05-04 02:01:20 (0.0 seconds) and wrote 1 record for NISS-NASDAQ | 2016-05-04 08:10:53
HD Request # 17 | Intraday download COMPLETE for NISS-NASDAQ. Completion time: 1s. Unique request ID: 16 | 2016-05-04 08:10:53
Removed historical data download ID 16 | 2016-05-04 08:10:53
Real-time Intraday chart data file updates started for NISS-NASDAQ | 2016-05-04 08:10:53
Opened cached Intraday file: C:\SierraChart\Data\NISS-NASDAQ.scid | 2016-05-04 08:10:53
Intraday chart data file opened for NISS-NASDAQ | 2016-05-04 08:10:53
HD Request # 18 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2016-05-04 08:10:53
HD Request # 18 | Download start Date-Time: 2016-05-04 02:01:20.000 | 2016-05-04 08:10:53
HD Request # 18 | Using server: ds5.sierracharts.com port 10149 | 2016-05-04 08:10:53
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-04 08:10:53
Socket (23) | Connected. | 2016-05-04 08:10:53
HD Request # 18 | Sending historical data logon request message. | 2016-05-04 08:10:53
HD Request # 18 | Requesting Intraday data. Start Date-Time: 2016-05-04 02:01:20. Record interval: 1. Symbol: NISS-SP | 2016-05-04 08:10:54
HD Request # 18 | Decompressing data. | 2016-05-04 08:10:54
HD Request # 18 | Receiving Intraday data for NISS-SP starting at 2016-05-04 02:01:20 | 2016-05-04 08:10:54
HD Request # 18 | Timestamp of first Intraday data file record written: 2016-05-04 02:01:20 | 2016-05-04 08:10:54
Socket (23) | Shutdown and closed. | 2016-05-04 08:10:54
The network socket for historical data has been closed. | 2016-05-04 08:10:54
HD Request # 18 | Received 1 record from 2016-05-04 02:01:20 to 2016-05-04 02:01:20 (0.0 seconds) and wrote 1 record for NISS-SP | 2016-05-04 08:10:54
HD Request # 18 | Intraday download COMPLETE for NISS-SP. Completion time: 0s. Unique request ID: 17 | 2016-05-04 08:10:54
Removed historical data download ID 17 | 2016-05-04 08:10:54
Real-time Intraday chart data file updates started for NISS-SP | 2016-05-04 08:10:54
Opened cached Intraday file: C:\SierraChart\Data\NISS-SP.scid | 2016-05-04 08:10:54
Intraday chart data file opened for NISS-SP | 2016-05-04 08:10:54
HD Request # 19 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2016-05-04 08:10:54
HD Request # 19 | Download start Date-Time: 2016-05-04 02:01:20.000 | 2016-05-04 08:10:54
HD Request # 19 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:10:54
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:10:54
Socket (24) | Connected. | 2016-05-04 08:10:54
HD Request # 19 | Sending historical data logon request message. | 2016-05-04 08:10:54
HD Request # 19 | Requesting Intraday data. Start Date-Time: 2016-05-04 02:01:20. Record interval: 1. Symbol: NISS-TF | 2016-05-04 08:10:54
HD Request # 19 | Decompressing data. | 2016-05-04 08:10:54
HD Request # 19 | Receiving Intraday data for NISS-TF starting at 2016-05-04 02:01:20 | 2016-05-04 08:10:54
HD Request # 19 | Timestamp of first Intraday data file record written: 2016-05-04 02:01:20 | 2016-05-04 08:10:54
Socket (24) | Shutdown and closed. | 2016-05-04 08:10:54
HD Request # 19 | Received 1 record from 2016-05-04 02:01:20 to 2016-05-04 02:01:20 (0.0 seconds) and wrote 1 record for NISS-TF | 2016-05-04 08:10:54
HD Request # 19 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 18 | 2016-05-04 08:10:54
Removed historical data download ID 18 | 2016-05-04 08:10:54
Real-time Intraday chart data file updates started for NISS-TF | 2016-05-04 08:10:54
Opened cached Intraday file: C:\SierraChart\Data\NISS-TF.scid | 2016-05-04 08:10:54
Intraday chart data file opened for NISS-TF | 2016-05-04 08:10:54
HD Request # 20 | Downloading Intraday chart data for UDVR-NYSE to the file UDVR-NYSE.scid. Service: statscalc | 2016-05-04 08:10:54
HD Request # 20 | Download start Date-Time: 2016-05-04 02:01:20.000 | 2016-05-04 08:10:54
HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2016-05-04 08:10:54
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-05-04 08:10:54
Socket (25) | Connected. | 2016-05-04 08:10:55
HD Request # 20 | Sending historical data logon request message. | 2016-05-04 08:10:55
HD Request # 20 | Requesting Intraday data. Start Date-Time: 2016-05-04 02:01:20. Record interval: 1. Symbol: UDVR-NYSE | 2016-05-04 08:10:55
HD Request # 20 | Decompressing data. | 2016-05-04 08:10:55
HD Request # 20 | Receiving Intraday data for UDVR-NYSE starting at 2016-05-04 02:01:20 | 2016-05-04 08:10:55
HD Request # 20 | Timestamp of first Intraday data file record written: 2016-05-04 02:01:20 | 2016-05-04 08:10:55
Socket (25) | Shutdown and closed. | 2016-05-04 08:10:55
The network socket for historical data has been closed. | 2016-05-04 08:10:55
HD Request # 20 | Received 1 record from 2016-05-04 02:01:20 to 2016-05-04 02:01:20 (0.0 seconds) and wrote 1 record for UDVR-NYSE | 2016-05-04 08:10:55
HD Request # 20 | Intraday download COMPLETE for UDVR-NYSE. Completion time: 1s. Unique request ID: 19 | 2016-05-04 08:10:55
Removed historical data download ID 19 | 2016-05-04 08:10:55
Real-time Intraday chart data file updates started for UDVR-NYSE | 2016-05-04 08:10:55
Opened cached Intraday file: C:\SierraChart\Data\UDVR-NYSE.scid | 2016-05-04 08:10:55
Intraday chart data file opened for UDVR-NYSE | 2016-05-04 08:10:55
HD Request # 21 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2016-05-04 08:10:55
HD Request # 21 | Download start Date-Time: 2016-05-03 21:05:00.000 | 2016-05-04 08:10:55
HD Request # 21 | Using server: ds5.sierracharts.com port 10149 | 2016-05-04 08:10:55
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-05-04 08:10:55
Socket (26) | Connected. | 2016-05-04 08:10:55
HD Request # 21 | Sending historical data logon request message. | 2016-05-04 08:10:55
HD Request # 21 | Requesting Intraday data. Start Date-Time: 2016-05-03 21:05:00. Record interval: 1. Symbol: TICK-NYSE | 2016-05-04 08:10:56
HD Request # 21 | Decompressing data. | 2016-05-04 08:10:56
HD Request # 21 | Receiving Intraday data for TICK-NYSE starting at 2016-05-03 21:05:00 | 2016-05-04 08:10:56
HD Request # 21 | Timestamp of first Intraday data file record written: 2016-05-03 21:05:00 | 2016-05-04 08:10:56
Socket (26) | Shutdown and closed. | 2016-05-04 08:10:56
The network socket for historical data has been closed. | 2016-05-04 08:10:56
HD Request # 21 | Received 1 record from 2016-05-03 21:05:00 to 2016-05-03 21:05:00 (0.0 seconds) and wrote 1 record for TICK-NYSE | 2016-05-04 08:10:56
HD Request # 21 | Intraday download COMPLETE for TICK-NYSE. Completion time: 0s. Unique request ID: 20 | 2016-05-04 08:10:56
Removed historical data download ID 20 | 2016-05-04 08:10:56
Real-time Intraday chart data file updates started for TICK-NYSE | 2016-05-04 08:10:56
Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid | 2016-05-04 08:10:56
Intraday chart data file opened for TICK-NYSE | 2016-05-04 08:10:56
HD Request # 22 | Downloading Intraday chart data for NQM6 to the file NQM6.scid. Service: cme | 2016-05-04 08:10:56
HD Request # 22 | Download start Date-Time: 2016-05-04 07:59:22.000 | 2016-05-04 08:10:56
HD Request # 22 | Using server: scdf1.sierracharts.com port 10149 | 2016-05-04 08:10:56
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-05-04 08:10:56
Socket (27) | Connected. | 2016-05-04 08:10:56
HD Request # 22 | Sending historical data logon request message. | 2016-05-04 08:10:56
HD Request # 22 | Requesting Intraday data. Start Date-Time: 2016-05-04 07:59:22. Record interval: 1. Symbol: NQM16 | 2016-05-04 08:10:56
HD Request # 22 | Decompressing data. | 2016-05-04 08:10:56
HD Request # 22 | Receiving Intraday data for NQM6 starting at 2016-05-04 07:59:22 | 2016-05-04 08:10:56
HD Request # 22 | Timestamp of first Intraday data file record written: 2016-05-04 07:59:22 | 2016-05-04 08:10:56
Socket (27) | Shutdown and closed. | 2016-05-04 08:10:56
HD Request # 22 | Received 374 records from 2016-05-04 07:59:22 to 2016-05-04 08:10:30 (11.1 minutes) and wrote 374 records for NQM6 | 2016-05-04 08:10:56
HD Request # 22 | Intraday download COMPLETE for NQM6. Completion time: 0s. Unique request ID: 21 | 2016-05-04 08:10:56
Removed historical data download ID 21 | 2016-05-04 08:10:56
Real-time Intraday chart data file updates started for NQM6 | 2016-05-04 08:10:56
Opened cached Intraday file: C:\SierraChart\Data\NQM6.scid | 2016-05-04 08:10:56
Intraday chart data file opened for NQM6 | 2016-05-04 08:10:56
HD Request # 23 | Downloading Intraday chart data for YMM6 to the file YMM6.scid. Service: cbot | 2016-05-04 08:10:56
HD Request # 23 | Download start Date-Time: 2016-05-04 07:59:26.000 | 2016-05-04 08:10:56
HD Request # 23 | Using server: scdf2.sierracharts.com port 10149 | 2016-05-04 08:10:56
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-05-04 08:10:56
Socket (28) | Connected. | 2016-05-04 08:10:56
HD Request # 23 | Sending historical data logon request message. | 2016-05-04 08:10:56
HD Request # 23 | Requesting Intraday data. Start Date-Time: 2016-05-04 07:59:26. Record interval: 1. Symbol: YMM16 | 2016-05-04 08:10:56
HD Request # 23 | Decompressing data. | 2016-05-04 08:10:57
HD Request # 23 | Receiving Intraday data for YMM6 starting at 2016-05-04 07:59:26 | 2016-05-04 08:10:57
HD Request # 23 | Timestamp of first Intraday data file record written: 2016-05-04 07:59:26 | 2016-05-04 08:10:57
Socket (28) | Shutdown and closed. | 2016-05-04 08:10:57
The network socket for historical data has been closed. | 2016-05-04 08:10:57
HD Request # 23 | Received 349 records from 2016-05-04 07:59:26 to 2016-05-04 08:10:32 (11.1 minutes) and wrote 349 records for YMM6 | 2016-05-04 08:10:57
Added 3 Time and Sales records to Intraday data file for YMM6 after download. | 2016-05-04 08:10:57
HD Request # 23 | Intraday download COMPLETE for YMM6. Completion time: 1s. Unique request ID: 22 | 2016-05-04 08:10:57
Removed historical data download ID 22 | 2016-05-04 08:10:57
Real-time Intraday chart data file updates started for YMM6 | 2016-05-04 08:10:57
Opened cached Intraday file: C:\SierraChart\Data\YMM6.scid | 2016-05-04 08:10:57
Intraday chart data file opened for YMM6 | 2016-05-04 08:10:57
Intraday data recording state for symbol VXX is set to download 'Pending'. | 2016-05-04 08:12:56
HD Request # 24 | Downloading Intraday chart data for VXX to the file VXX.scid. Service: equities.us | 2016-05-04 08:12:56
HD Request # 24 | Download start Date-Time: 2016-05-03 19:07:59.000 | 2016-05-04 08:12:56
HD Request # 24 | Disabling Intraday chart updating for symbol during historical data download. | 2016-05-04 08:12:56
HD Request # 24 | Using server: ds3.sierracharts.com port 10149 | 2016-05-04 08:12:56
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164. | 2016-05-04 08:12:56
Socket (30) | Connected. | 2016-05-04 08:12:56
HD Request # 24 | Sending historical data logon request message. | 2016-05-04 08:12:56
HD Request # 24 | Error downloading historical Intraday data for VXX. Historical data logon error: Invalid/missing data for service code: equities.us | 2016-05-04 08:12:56
Socket (30) | Shutdown and closed. | 2016-05-04 08:12:56
The network socket for historical data has been closed. | 2016-05-04 08:12:56
HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for VXX | 2016-05-04 08:12:56
HD Request # 24 | Intraday download COMPLETE for VXX. Completion time: 0s. Unique request ID: 23 | 2016-05-04 08:12:56
Removed historical data download ID 23 | 2016-05-04 08:12:56
Real-time Intraday chart data file updates started for VXX | 2016-05-04 08:12:56
Opened cached Intraday file: C:\SierraChart\Data\VXX.scid | 2016-05-04 08:12:56
Intraday chart data file opened for VXX | 2016-05-04 08:12:56
HD Request # 24 | Enabling Intraday chart updating for symbol. | 2016-05-04 08:12:56
[2016-05-04 07:27:32]
For this:
Description: VIX Short-Term Futures ETN Ipath
Symbol: VXX
You need to activate the "US Equities" exchange.
We should have recognized that earlier.
