Date/Time: Sat, 28 Dec 2024 23:09:50 +0000
User Email
View Count: 815
[2016-05-03 16:28:30]
Sierra Chart - Max - Posts: 5770
Please take a look at the screeshot, I already wrote about this matter and you sent me a link toi the boeard but it was in regards to an old request that was already solved.
The problem now is that using the countdown on 1 minute chart, the indicator start the countdown at 2 minutes and 20 seconds; in the chart time frame 5 minutes the countdown starts at 6 minutes instead of 5 minutes.
Is there a way to solve this problem?
Thank you
Kind Regards
Sierra Chart Support
imageCattura 2.JPG / V - Attached On 2016-05-03 16:27:22 UTC - Size: 239.2 KB - 313 views
imageCattura.JPG / V - Attached On 2016-05-03 16:27:35 UTC - Size: 235.27 KB - 286 views
imagesettaggi count down.JPG / V - Attached On 2016-05-03 16:27:45 UTC - Size: 117.23 KB - 265 views
[2016-05-03 17:43:57]
Update Sierra Chart by selecting Help >> Download Prerelease.
Here are detailed instructions:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
After the update select Global Settings >> Set System Date-Time from Server.
[2016-05-04 23:34:29]
The client did all that was suggested, but it is impossible in Global Settings to find Set System Date-Time from Server. Where it is?
[2016-05-05 04:37:15]
They need to update to the latest prerelease version to see that new command.
Date Time Of Last Edit: 2016-05-05 04:53:20
