Date/Time: Thu, 10 Sep 2026 07:15:01 +0000
Eurex/CBOE data
View Count: 1058
| [2016-05-03 16:02:38] |
| User182649 - Posts: 31 |
Last night I activated the Eurex and CBOE data feeds. I see that the fees were added to monthly data charges. Under the activation page, I do see where both appear to have been activated. However I see nothing in the transaction log nor am I able to locate any CBOE/EUREX futures symbols. I have rebooted Sierra Chart a number of times Thanks |
| [2016-05-03 17:28:55] |
We see you are using TD Ameritrade. What EUREX symbols did you want to chart? For the CBOE index symbols you can find those in File >> Find Symbol >> Indexes (real-time data). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-03 18:59:48] |
Dax Index (DY) and the mini Dax (DM) are the two primary indicies. I believe the CBOE exchange also trades the VIX futures contract (VX) in addition to the spot vix. If I am mistaken, then I will deactivate this subscription. Thx |
| [2016-05-03 19:23:45] |
These EUREX symbols have been added to the symbol list for TD Ameritrade. Restart Sierra Chart. VIX futures is a different exchange: CFE Futures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
