Date/Time: Tue, 15 Sep 2026 03:17:52 +0000
TPO Profile Volume Issue
View Count: 1185
| [2016-05-03 09:41:14] |
| kas64h - Posts: 87 |
Hello. I updated to Sierra Chart version 1400 last week, and since then my TPO Profile Charts no longer seem to be working correctly. I split out these profiles to give me areas of liquidity based on Volume, and therefore base both the Value Area and Point of Control on Volume. However, the following settings no longer seem to work: 'Value Area Highlight Based On Volume' and 'Point Of Control Highlight Based On Volume'. If I set both to either Yes or No, the Value Area and Point Of Control DO NOT CHANGE (when clearly they should). I've attached a screenshot (including my settings), to demonstrate this. The Profiles to the left are TPO Profiles with both the 'Value Area Highlight Based On Volume' and 'Point Of Control Highlight Based On Volume' settings set to 'Yes'. The Profiles to the right are simply VbP Volume Profiles. The Value Area and POC for each profile should align, and clearly they don't. It looks to me as though the Value Area and POC are both being based on time rather than volume (as indicated by the 'Value Area Highlight Based On Volume' and 'Point Of Control Highlight Based On Volume' settings being set to Yes). I haven't changed any of my settings since doing the update to version 1400. I've included my settings in case there is something else I need to change since the update. Thank you for your help. |
Private File |
| [2016-05-03 10:49:34] |
This is now fixed. It relates to recent changes that have been made. Update Sierra Chart to the latest prerelease following the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
