Date/Time: Sat, 28 Dec 2024 22:40:18 +0000
Hi, I am a new user of sierra chart on a 15 days free trial version,
View Count: 634
[2016-05-03 01:57:47] |
User239482 - Posts: 2 |
My ES futures charts do not move unless I keep disconnecting and connecting the chart, do not know why? it shows all are green means the connection is good
[2016-05-03 05:02:31] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php You really should be aware, that there is no chance to be getting real-time futures data this easily for free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
