Date/Time: Sat, 28 Dec 2024 23:29:49 +0000
Confirm Order Modifications
View Count: 909
[2016-05-02 20:57:37] |
User150371 - Posts: 70 |
In the Order Window Menu,I have unchecked all Confirmations. But when I switch back and forth between from Order types- eg from Simple Bracket to 2 Targets with Common Stop, the Confirm Order Modifications keeps being re-checked, no matter how many times I uncheck it. None of the other Confirmations are affected. Can I prevent this from happening or permanently disable all confirmations ? Thanks.
[2016-05-02 21:50:12] |
How to solve this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#OrderConfirmations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
