Date/Time: Sat, 28 Dec 2024 22:30:17 +0000
Backtest Consistency
View Count: 611
[2016-05-02 18:03:42] |
JamesP - Posts: 89 |
Hello, When I run a Auto trade replay backtest(ES) and then rerun it again, exact same settings and dates I'm seeing slight differences. For example a different number of trades taken or P/L. It's not a major difference so if this just has something to do with slightly diff. fills or how the keltner or bars formulate slightly different no big deal,I just want to make sure there are no issues with my spreadsheet formulas. Is this something that happens regularly or should I be seeing the exact same number of trades, Profit e.t.c? Thanks for your time. |
[2016-05-02 18:08:37] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Backtesting.php#BackTestConsistency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
