Date/Time: Thu, 10 Sep 2026 16:39:17 +0000
Current Price Bar Not Showing. Futures Volume Incongruency Issues
View Count: 965
[2016-05-02 17:36:12]
User347150 - Posts: 29
Thank you for letting me know how to set up continuous charts. I am noticing that the last bar in the intraday charts, the present bar being formed reflecting the current price, in not being displayed on the charts. Also there is a difference between the volume that is displayed on each of the price bars, as well as daily bars, when I compare the volumes on my Sierra charts to the volumes on www.barchart.com. Let me give you an example of what I am mean. Futures data and volume are suppose to be the same from the exchange, especially daily volume. The volume for the emini S & P 500 for Friday April 29, 2016 was 2,408,461, according to www.barchart.com. The volume on my Sierra Chart for the same contract and date is displayed as 2,419,757. Similar incongruencies appears to occur on the intraday time frames as well. Please help me if you can. Thank you very much.
Sincerely,
Everett
[2016-05-02 17:51:37]
Refer to help topic 3:
Https://www.sierrachart.com/index.php?l=helpdetails3.html
For data differences, refer to help topic 43:
Https://www.sierrachart.com/index.php?l=helpdetails43.html
Also for the ES June 2016 Futures the correct daily volume for 2016-04-29 is: 2,419,757.
[2016-05-02 18:50:58]
Thank you for your help. Under topic 3, I do not see a section that covers my issue with the current bar not being displayed. Although I checked several times, I may be overlooking it. Please help if you can.
[2016-05-02 18:54:49]
Most likely the reason is the chart is not scrolled to the end?
Refer to:
https://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.8
Help topic 3 is very comprehensive. Review all of the items again.
[2016-05-02 19:03:52]
No. The chart is scrolled all the way to the end. The last bar is just not being displayed.
[2016-05-02 19:08:12]
It is okay now. I closed and reopened Sierra Charts, and the problem disappeared. Thank you very much. Take care.
Sincerely,
Everett
[2016-05-02 19:08:55]
Therefore, what you are describing is a problem where an Intraday chart is not updating.
So refer to the other items in help topic 3 to determine why:
[2016-05-02 19:11:16]
This indicates a problem with the data feed itself. There is never a need to restart in this particular case. Refer to help topic 3.4:
https://www.sierrachart.com/index.php?l=doc/helpdetails3.html#h3.4
Date Time Of Last Edit: 2016-05-02 19:11:53
