Date/Time: Sat, 28 Dec 2024 21:55:31 +0000
custom dll removal
View Count: 603
[2016-05-02 16:38:29] |
User248850 - Posts: 1 |
I have tried numerous times to remove a custom dll that is making sierra unstable but I can't seem to get rid of it
[2016-05-02 16:42:22] |
You need to look at all of the charts you have in all of the open Chartbooks. Refer to help topic 17: https://www.sierrachart.com/index.php?l=helpdetails17.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
