Date/Time: Fri, 20 Sep 2024 00:44:47 +0000
Custom Study run only real time datas
View Count: 1555
[2013-07-09 16:21:45] |
User40073 - Posts: 23 |
Hello, How to code to my study, calculates run only real time datas? Always run on my historical datas.:( regards, ebandit |
[2013-07-09 22:03:56] |
There is nothing special to do. All studies will update with real-time data as long as you are connected to the real-time data feed. All of the Sierra Chart studies which are provided in the /ACS_Source folder, all will update in real-time. There is nothing special to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
