Date/Time: Sat, 28 Dec 2024 23:29:07 +0000
Assistance Needed
View Count: 767
[2016-05-02 02:42:53] |
User389267 - Posts: 7 |
Hey! I have been working rather diligently on Sierra Charts trying to build a "system" of sorts. I am absolutely in love with the platform. I have a question for the team however; is there a way to "activate" an indicator (ie. Supertrend Stop) once your "Color Bar" indicator goes off? In other words, can I get the Supertrend to work as my stop loss for the "Color Bar" alert I have? The Supertrend indicator does not need to change at all. I just want to be able for it to not start until the "signal bar" activates.
[2016-05-02 19:00:03] |
No. There is nothing like this for studies. However, there is this study which can be used to control a Stop order: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#StudyControlledTargetsStops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-02 23:19:34] |
Sawtooth - Posts: 4143 |
You could use a spreadsheet study to hide the Supertrend until your alert.
