Date/Time: Fri, 04 Apr 2025 21:54:59 +0000
[User Discussion] - Had to reinstall Sierra - now missing custom studies
View Count: 983
[2016-05-02 00:56:18] |
djcurcio - Posts: 236 |
Kiwi and to the Tick missing and they now do not show in the add custom studies drop down help please thanks Software version: 1402 | 2016-05-02 00:41:36 Error loading custom studies DLL: C:\SierraChart\SierraChartTransActMA\Data\ToTheTickZones.dll. Windows error code 126: The specified module could not be found. | 2016-05-02 00:46:52 * Error loading custom studies DLL: C:\SierraChart\SierraChartTransActMA\Data\kiwi12.dll. Windows error code 126: The specified module could not be found. | 2016-05-02 00:46:52 * |
[2016-05-02 07:44:36] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html#Errors Those files are missing. For the kiwi12.dll file, you can find all of those same studies in Analysis >> Studies >> Add Custom Study >> User Contributed Studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-06 00:28:52
[2016-05-05 23:20:32] |
Still can't find it. Where is this ? Analysis >> Studies >> At Custom study >> User Contributed Studies. A link please thanks |
[2016-05-06 00:29:10] |
There was a slight dictation error. We meant: Analysis >> Studies >> Add Custom Study >> User Contributed Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-06 00:45:15] |
Please provide the link to the referenced page - i can;t find it.And - btw - searching on Kiwi12.dll doesn't work Seems the support search needs a fix thanks |
[2016-05-06 04:53:12] |
You will not see the Kiwi12.dll listed itself, but you should find the same study names listed in the User Contributed Studies. If not, then they are not available there. We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-05-31 05:19:28] |
Kiwi - Posts: 375 |
SC are correct that you'd be better of using the versions of the studies in User Contributed Studies - basically they cleaned up some of my old studies and maintain the code. If you can't figure out the name of the study here's a copy of kiwi12.dll that was compiled back in 2013 that you could use to check which study it is. Once you figure out what it is, switch to the UCS version if you can. You need to save the file in your /sierrachart/data directory at which point the error message should disappear and you can use F6 to figure out which study it is. Date Time Of Last Edit: 2016-05-31 05:20:31
Private File |
