Date/Time: Sat, 28 Dec 2024 22:30:42 +0000
NIY-201606-GLOBEX not working
View Count: 617
[2016-05-01 22:57:49] |
rhovega - Posts: 279 |
Not receiving quotes for NIY-201606-GLOBEX (IB data). SC log says "symbol unknown to the server". It was working on Friday, and I have NIY streaming from a different data feed. NKD-201606-GLOBEX (the usd denominated and less liquid version of NIY) works just fine. Can you please look into this, or should I contact IB? Thanks.
[2016-05-01 23:05:36] |
You are using the older symbol format. Select File >> Find Symbol locate the contracts for: NIY-######-GLOBEX-JPY-500 and use one of those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-01 23:05:57
