Date/Time: Fri, 20 Sep 2024 01:09:00 +0000
Toolbar
View Count: 1962
[2013-07-09 15:05:43] |
Ed Meckelborg - Posts: 71 |
I lost my toolbar. How do I get it back?
[2013-07-09 16:58:35] |
Sierra Chart - Max - Posts: 5662 |
Select Windows >> ToolBars >> ToolBar 1. For more information, please see: https://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar Sierra Chart Support |
[2013-07-09 17:13:23] |
I did that. It does not run horizontally across the top. I do get a box containing the tools
[2013-07-09 17:18:08] |
Refer to the Moving and Detaching the ToolBar section under: https://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar You can drag the ToolBar to the top of Sierra Chart with your mouse to reattach it. Sierra Chart Support |
[2013-07-09 17:49:00] |
I cannot get the tool bar across the top
[2013-07-09 18:01:35] |
I have a mess. The high/lows for the day are not across the top. and I cannot get the tool bar across the top. please help |
[2013-07-11 18:32:54] |
Are you referring to a Historical Daily bar chart? In regards to the ToolBar, we have provided you specific help with that. Once again here is the documentation: https://www.sierrachart.com/index.php?l=doc/doc_WindowMenu.html#ToolBar Refer to the documentation because it explains what to do if you cannot see the ToolBar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-11 18:34:36
