Date/Time: Sat, 28 Dec 2024 21:47:21 +0000
Numbers Bars - open close arrow, minor bug
View Count: 736
[2016-05-01 18:01:54] |
User365411 - Posts: 192 |
Found a bug applying Number Bars study on the E6 EuroUsd future. With TickSize= 0.00005, open and close arrows are correctly displayed, but with TickSize= 0.0001 someone disappear, noted that happens when open or close price is on the half tick that CME recently implemented on E6 future. Other values in TickSize not equal to 0.0001 works correctly. http://www.sierrachart.com/image.php?Image=1462125616149.png |
[2016-05-01 21:15:41] |
We will see if it is reasonable to solve this.
