Date/Time: Mon, 13 Jan 2025 07:30:20 +0000
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
View Count: 1063
[2016-05-01 17:39:48] |
conr - Posts: 204 |
In the documentation it says to copy Sierra3.cfg, Accounts.config, etc. My question is there are those I just mentioned plus Sierra3.cfg.Friday, Sierra3.cfg.Monday and so on. Do I need to copy all those as well?
[2016-05-01 19:06:29] |
No you do not need to copy those other ones with the day of week names at the end. They can be deleted.
[2017-04-15 06:57:31] |
3152sier - Posts: 52 |
this needs to be simplified for those who are not scientists; wondering where to copy, on a flash drive? Date Time Of Last Edit: 2017-04-15 07:03:42
[2017-04-15 13:46:10] |
Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
