Date/Time: Sat, 28 Dec 2024 23:27:20 +0000
Average daily Range marked on the chart itself
View Count: 1424
[2016-05-01 01:21:39] |
User17064 - Posts: 70 |
Hi SC support, I'm looking for the daily range study, I marked the request in the attachment. Basically,it should calculator avearge daily range with formula with start time and end time requeted.Then marked on the intraday chart where is ADV hi and where is ADV lo. I try to find the default ADR study in the SC but no result. Thanks! Date Time Of Last Edit: 2016-05-01 01:22:29
2016-05-01_9-16-37.png / V - Attached On 2016-05-01 01:22:19 UTC - Size: 35.75 KB - 570 views |
[2016-05-02 09:05:12] |
User13668 - Posts: 294 |
They are in the drop down Studies list. Daily Range study is called 'Daily Range Band' and the ADR is called 'Average Daily Range' |
[2016-05-02 21:56:11] |
Use the Average Daily Range study on an Intraday charts set to Daily bars: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s347 https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#CreatingDailyBarsCustomSessionTimes And then use the Study/Price Overlay study: https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-02 21:56:22
