Date/Time: Sat, 14 Nov 2026 03:35:21 +0000
Hide Account Number?
View Count: 3195
[2016-04-30 23:58:29]
greg9 - Posts: 9
Sierra Chart
Is there a way to hide my account number or star it out ********** or something else? I like to screenshot and share my my trading view but don't like having to always remember to blank out the account number?
I tried searching for a solution to this.... didn't find one.
Greg
imageaccount.jpg / V - Attached On 2016-04-30 23:57:35 UTC - Size: 155.11 KB - 635 views
[2016-05-02 09:10:44]
User13668 - Posts: 296
A member at Futures.io (who is a programmer) wrote a Study that does it exactly what you ask (although I have not tried it).
https://futures.io/download/sierra_chart/1199-download.html?view
[2016-05-02 16:50:12]
We recommend using the Edit >> Screen Images >> Save Chart to File command:
Sierra Chart Image Upload Service: Saving Images To Your Computer
[2016-05-02 21:29:40]
greg9 - Posts: 9
This function: Edit >> Screen Images >> Save Chart to File
Just captures 1 window. I have a 4 charts and a DOM that I want to capture. So this isn't going to work.
The futures.io solution has 3 indicators all packaged into it. 2 of them work, unfortunately the hide account number indicator in the package didn't work. I installed it, used it as is, didn't work, changed the settings around, still couldn't get it to work. Any idea what i'm doing wrong?
imageHide Account.jpg / V - Attached On 2016-05-02 21:29:02 UTC - Size: 166.98 KB - 631 views
[2016-05-03 05:14:41]
This question is not within the scope of our support.
[2016-05-03 06:38:41]
As I said, I have not tried the Study myself.
Are you trying this Study by applying it to the DOM itself and not to the Price chart?
This study was posted in June 2012 so SC have had many version releases since then, so the SC underlying s/w may have changed in some aspect that affects this study.
Assuming you are a member of Futures.io, why don't you create a post and 'shout out' to the member who wrote it for help [format is @xxxxxx] or send them a private message from within Futures.io.
[2016-05-03 13:57:16]
greg9 - Posts: 9
Yes I was trying to apply it to the DOM.
I reached out to ktrader to see if he has it working or to troubleshoot it.
Thanks everyone
