Date/Time: Sat, 28 Dec 2024 23:37:08 +0000
Numbers Bars bug found in latest pre-release version
View Count: 870
[2016-04-30 00:24:06] |
User50927 - Posts: 91 |
The new "Ask Bid Vol Difference Diagonal" option added to the "Numbers Bars Text" is showing the diagonal deltas in reverse/backwards order compared to the beginning of the week: http://www.sierrachart.com/image.php?Image=1461974148318.png If you compare that image to a similar picture I uploaded on Mon 4-26, right after the original release of that study option, you will notice that that bug wasn't there before (negative delta values on the left column and positives on the right): http://www.sierrachart.com/image.php?Image=1461676928919.png Other than that, a "background coloring method" option "Based On AskVol BidVol DIAGONAL Difference Percentage" still needs to be added to the study to finalize the upgrade. The upgraded study is complete otherwise and much appreciated!! Thank you in advance. |
[2016-05-03 05:35:20] |
This has been corrected.
