Date/Time: Sat, 28 Dec 2024 22:25:41 +0000
[Info]New Volume/Market Profile and Orderflow studies available
View Count: 3142
[2016-04-29 18:39:13]
gomifromparis - Posts: 244
Sorry for self promotion, I just wanted to mention I published new Volume/Market Profile study and a new OrderFlow study for Sierra on http://www.gomicators.com
Sierra comes with built-in Volume by Price and Number Bars, however the Gomicators ones offer added/different possibilities
GomMPPro (Market Profile)
*Allows smoothing to have a better vue on jiggery profiles
*Multipe profile modes including showing delta-based profiles
*Allows adding custom-drawn profiles
*Uses hotkeys to toggle between preferred settings, increase/decrease size, increase/decrease smoothing
*Customizable Hotkeys
*Shows POC VWAP VA and continuous drawing of those
*Shows High Value/Low Value nodes
*Can be offset horizontally, and displayed left-to-right or right-to-left
*Uses highly optimized C# objects and is much much faster than Volume By Bars, so if you find the native VbP is slowing down your Sierra, you can give the GomMPPro a try
GomOrderFlow
*Displays a "familiar" orderflow view out-of-the-box
*Multiple auto-sizing options
*Calculates/Displays horizontal/diagonal imbalances
*Shows S/R zones based on consecutive imbalance levels
*Shows unfinished autions & POC
*Shows naked unfinished auctions & POC lines
*Displays bar delta info (min/max/close/finish)
*Displays COT
*Hotkeyed for fast settings toggle
A free 20 days trial is available on the web site.
Gomi
imagesierraOF1.3.png / V - Attached On 2016-04-29 18:33:59 UTC - Size: 150.36 KB - 4999 views
imagesierraprof1.png / V - Attached On 2016-04-29 18:34:06 UTC - Size: 47.5 KB - 1266 views
imagesierraprof2.png / V - Attached On 2016-04-29 18:34:10 UTC - Size: 35.43 KB - 964 views
imagesierraprof3.png / V - Attached On 2016-04-29 18:34:15 UTC - Size: 47.63 KB - 973 views
