Date/Time: Sat, 28 Dec 2024 21:50:48 +0000
current announcements thread
View Count: 843
[2016-04-29 14:59:25] |
kinghat - Posts: 120 |
are you guys going to make the new current announcements thread that is locked stickied to the top of the forum for easy access?
[2016-04-29 15:18:28] |
No there is no plan for this.
[2016-04-29 15:20:55] |
so we need to bookmark it to keep track of it?
[2016-04-30 19:41:05] |
User13668 - Posts: 294 |
Agree with this suggestion. Should be stickied so that no matter how often we check the Support Board, the customer will always see the latest announcements thread.
