Date/Time: Sat, 28 Dec 2024 08:09:31 +0000
Restart Sierra Chart
View Count: 819
[2016-04-29 13:38:50] |
User905901 - Posts: 18 |
Hallo, can you tell me, how to restart Sierra Chart? I can not see this option. Regards. |
[2016-04-29 14:18:00] |
You select File >> Exit. And start Sierra Chart again using the icon for it on your system desktop. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
