Date/Time: Sat, 28 Dec 2024 08:13:19 +0000
AWL
View Count: 918
[2016-04-29 02:55:20] |
madra - Posts: 109 |
Hello, using awl: adding a new symbol in the find box and clicking FS the find window appears. I have to re-enter the symbol in the find symbol window. Up to a couple days ago when I clicked on the FS window the new symbol would already be in this window. Question: Is there a way to revert to not having to re-enter the symbol in the find symbol window. Thank you Charlie |
[2016-04-29 03:15:37] |
If you want to add new symbols which will be listed in the Find Symbol window this needs to be done through Global Settings >> Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php There is no other way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
