Date/Time: Sat, 28 Dec 2024 08:41:03 +0000
User Email
View Count: 783
[2016-04-28 21:08:37] |
Sierra Chart - Max - Posts: 5770 |
Hello, Please take a look at the screenshots. The client is using the study countdown. In 1 minute chart the study starts the countdown at 2 minutes and 30 seconds, in the 5 minutes chart is starts at 6 minutes instead of five. In the third screenshot there are the settings that the client is using. Is there a way to solve his problem ? Thank you Kind Regards Sierra Chart Support |
Private File Private File Private File |
[2016-04-29 04:24:06] |
The problem is that the computers Date and Time is not set accurately. Refer to help topic 38: Https://www.sierrachart.com/index.php?l=helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
