Date/Time: Sat, 28 Dec 2024 08:41:14 +0000
User Email
View Count: 650
[2016-04-28 21:06:05] |
Sierra Chart - Max - Posts: 5770 |
On TransAct's version of the charting is there something that needs to be enabled to allow moving multiple contract stop orders one at a time? My customer is saying that it will only allow him to move all the orders on a 2 lot and they do not move as 1 lots like they do on the standalone version from you guys directly...please advise Sierra Chart Support |
[2016-04-29 04:34:55] |
If they are using Attached Orders they just need to make sure that there is a single Stop order and the OCO Group setting is set to All OCO Groups. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#OCOGroup Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-04-29 04:35:15
