Date/Time: Thu, 17 Sep 2026 03:09:58 +0000
Forex
View Count: 874
| [2016-04-28 14:59:39] |
| User39772 - Posts: 311 |
Helli, can you give some details about the SC forex data feed. Whe I open an T&S window and add colums "volume" and "num trades" there is for each tick always a "1" in these cells. What does this 1 mean and why is it always only one (compared to stocks futures you can see the number of e.g. contracts which can be > 1 of course). |
| [2016-04-28 17:05:56] |
Refer to: Chart Data and Chart Data Files: Volume Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
