Date/Time: Fri, 20 Sep 2024 00:43:37 +0000
[User Discussion] - GUPPY Stochastic Study
View Count: 2531
[2013-07-09 11:44:17] |
User37170 - Posts: 29 |
What would be the most efficient way to do this? Similar to Guppy MMA ... multiple moving average] In my Stochastic Window I want multiple [Slow] Stochastics each with its own setting Need upper band and lower band to show ONCE I can do it by putting multiple studies in same window ... Is this acceptable? K. |
[2013-07-09 12:51:45] |
Sawtooth - Posts: 4091 |
Yes, multiple instances set to the same chart region is the way to do it.
[2013-07-10 04:42:25] |
vegasfoster - Posts: 444 |
Made this a while back for...something. Anyway, multiple stochs from 6-24. Can't change the periods, but may be useful for you.
SpudfyreStoch.cpp - Attached On 2013-07-10 04:41:56 UTC - Size: 7.11 KB - 741 views SpudfyreStoch.dll - Attached On 2013-07-10 04:42:15 UTC - Size: 127.5 KB - 658 views |
[2013-07-10 08:02:19] |
Very useful. THANK-YOU.
